585,959 active members*
4,915 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Probe connections to Pulsar
    May 2017
    18
    I just bought a probe for my Pulsar. This one here: https://www.kurokesu.com/shop/precis...struments/TPA2 . From the specs it seems like it was a decent compromise between the cheaper probes you can find and an old Renishaw.
    My question is - how do you connect it to the Pulsar. I'm still pretty new to this system. I'm in the process of installing PP right now as well. I assume it goes to the header on the BOB, but I can't find where. Any help would be appreciated. The switch is "passive" in that it's an open when tripped.
    Thanks.
    - Rick
    Aug 2007
    701
    Re: Probe connections to Pulsar
    Rick that’s a nice looking probe and pretty reasonable $. I forget which pin I think it’s pin 17 - but check the hal file. If it’s not powered then one pin to gnd and the other to pin 17 of the BOB.
    Jan 2016
    386
    I'm pretty sure I am using pin 15 on my probe. I'll check later when I am home.
    Jan 2016
    386
    Yes, I'm using pin 15 on the BOB for my probe.
    May 2017
    18
    Quote Originally Posted by Steve303 View Post
    Great. So just one wire to pin 15 and the other to ground.
    Also - did you guys do anything to tram/square the head to the table? I've only done that kind of thing on an old bridgeport machine. It seems like it would have to e done with shims or something on this tool if necessary. Or was it close enough as delivered? I haven't measured this yet but intend to soon.
    - Rick
  1. Replies: 15
    Last Post: 02-26-2018, 03:00 AM
  2. Acurite MillPwr - connections for edge finder / probe
    By rayg in forum Bridgeport / Hardinge Mills
    Last Post: 04-24-2013, 10:33 PM
  3. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  4. Syil X4+ probe or tool depth gauge wiring connections
    By Mac Tech in forum Syil Products
    Last Post: 08-25-2011, 12:53 PM
