585,981 active members*
4,093 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Recommendation for long x axis CNC mill
Results 1 to 2 of 2
    Apr 2016
    7
    All,
    We are bidding on a new contract/grant that requires a CNC mill that can handle a part about 60 inches in length. Y and Z motions are modest, about 12-16 inches. Can anybody recommend a mill that can handle this that won't cost like the latest national debt. The part to be machined is not very heavy, about 40 pounds, the rotary table we use weighs way more than that. We have smaller versions of this project working on a Tormach PCNC-1100 with a bed extender. Wish Tormach made a bigger machine.
    Apr 2014
    345
    Re: Recommendation for long x axis CNC mill
    Since you posted in the fadal forum I figure you want a fadal? Maybe go out and look for a used vmc 6030 or 8030 they should both suit your needs. And as slow as they are I think they are still faster than a tormach.
  1. Spindle+VDF recommendation for long jobs cutting 18mm Plywood below €1000
    By javito in forum DIY CNC Router Table Machines
    Last Post: 05-17-2013, 10:27 AM
  2. Recommendation for vertical mill w/4th axis
    By extanker59 in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2013, 08:22 PM
  3. Long axis router on mill
    By MechanoMan in forum DIY CNC Router Table Machines
    Last Post: 01-15-2009, 01:31 AM
  4. mill recommendation
    By rickyt in forum Milltronics
    Last Post: 05-08-2006, 05:07 PM
  5. Need 3-axis CNC vertical mill recommendations <$10k (Long post)
    By PCS74 in forum Uncategorised MetalWorking Machines
    Last Post: 03-08-2006, 07:38 AM
