585,956 active members*
4,623 visitors online*
    Jun 2016
    184
    Question Mist Collector Options
    Anyone can recommend good mist collector/filter for the enclosure, preferably so its easily mounted on that 4" opening they have on top of enclosure? I am aware of Mistaway but those are huge, way too large for the little Slant Pro.
    Jun 2016
    184
    Re: Mist Collector Options
    Found Royal Filtermist products. Looks great, but 3-phase power is no go for even a smaller unit :-(
    Aug 2016
    132
    Are you looking to control the mist collector with an M code? If not, a rotary phase converter makes your search much easier. You're going to be hard pressed to find small units, since machine shops don't really care about having compact machines.
    I'd be hesitant to try to mount anything on the sheet metal of the enclosure. Why not mount it on a floor stand or from the ceiling?
    Jan 2016
    79
    Quote Originally Posted by coffeetek View Post
    Simply use a low cost 1 phase in / 3 phase out VFD to drive Royal's 3-phase motor. Depending on the motor power this could be as low as $100-200.
  1. Dust collector
    By Roctech-Mercy in forum Roctech CNC Routers
    Last Post: 04-22-2015, 04:02 AM
  2. Mist collector? Can I build my own?
    By mflux_gamblej in forum Uncategorised MetalWorking Machines
    Last Post: 07-26-2014, 02:31 PM
  3. DIY Oil Fog Collector (or Mist Collector)
    By Deltic_Engine in forum Uncategorised MetalWorking Machines
    Last Post: 04-07-2008, 09:47 PM
  4. Dust collector
    By SPEEDRE in forum DIY CNC Router Table Machines
    Last Post: 06-30-2007, 02:45 PM
  5. Let’s see that’s dust collector
    By automizer in forum DIY CNC Router Table Machines
    Last Post: 03-15-2006, 01:41 PM
