585,992 active members*
5,238 visitors online*
Results 1 to 7 of 7
    Mar 2007
    18
    Weight of mobile parts
    I wish to construct the big table for plasma cnc. I collect the information and I analyze it. I have constructed more than 20 machine tools and machines, but I never built cnc. I consider, that for plasma loading, only inertia of parts of the machine are sharp important small weight of mobile parts/inertia/is absent. But I do not understand, why almost everyone do heavy machine tools?
    May 2005
    674
    What do you mean by "heavy"? Most plasma machines I've seen are very lightweight for the reasons you mentioned.
    A 4'x8' (1200 x 2400mm) capacity table is typically well under 1000 lbs. Compare this to similar sized machining centers that weigh 20,000 lbs.
    Mar 2007
    18
    [QUOTE=Zumba;281951]What do you mean by "heavy"? Most plasma machines I've seen are very lightweight for the reasons you mentioned.
    A 4'x8' (1200 x 2400mm) capacity table is typically well under 1000 lbs.ompare this to similar sized machining centers that weigh 20,000 lbs.[/
    I mean only weight of Y- axis Gantry .I consider, that this main thing. Capacity of motors depends on weight and therefore capacity of electronics and therefore the price. The weight of a table has no value. It it is possible will make even of concrete. It is necessary to do Y-axis Gantry even easier. To clean motors from it and to use other technical decisions. Unified aluminium a structure well, but original Y- axis Gantry is better. Nobody can tell what weight is optimum. How will run Y-axis Gantry if it will be 20 pounds weigh?
    I mean only a plasma table.
    Aug 2005
    828
    Oleg, Kak pogoda y vas?
    Take a look at this mobile plasma/oxy cutter pretty trick!
    http://www.steeltailor.com/
    Small light and portable, would be a great item for any metal fab shop.
    Dennis
    Mar 2007
    18
    Quote Originally Posted by DennisCNC View Post
    Privet,y nac dozhdi,tocka.
    SteelTailor P is Very beautiful !!!
    Many thanks!
    Mar 2007
    18
    Only Z Axis Manually Adjustable, Inclinable.The original design always is the compromise.I know as to get rid of lacks. I have drawn figure.I have sent on e-mail the letter to the engineer Philippe Glaude
    with the enclosed figure how to modernize the SteelTailor P, to make its more mobile and convenient on manufacture.
    Now I think, that it not modernization, and essentially other design.This design can work with a water table and move on manufacture. The weight will be no more than 100 kg.. It is obligatory to include THC.
    Attached Files Attached Files
    Mar 2007
    18
    All greetings!
    I think, that the offered scheme of plasma CNC meets my industrial requirements.
    I was defined with a design plasma CNC. Portable plasma CNC should not mean simply and cheaply. I think, that definition portable plasma CNC bears any defective sense. I think, that it is wrong. The main thing to provide productivity and a production efficiency.
    The important factor is a zone of service-area borrowed by the equipment and materials. A floor space very dear. It can cost more expensively the equipment.
    I think to make plasma with the working size 1.5 on 3.5 meters.
    The weight of a design will be about 80 kg. I think to use a rotary axis X and rotary legs for reduction of a dimension in a non-working condition. I wish to refuse a separate axis Z and to move on height on 0.3 meters all axis X in gathering.For this purpose I wish to use telescopic linear directing.
    . It will make a design of more universal. We can cut metal sheets of any sizes.
    If to cut very heavy metal sheets the heavy table is necessary. What for?
    I think, that it is inefficient to build heavy tables/even of 400 kg/. The metal leaf can be put on a floor through cheap linings. It is fair only for industrial production.
    And still. To me it is thought, that linings which lay on a floor, it is easier to replace or repair than the linings established on a plasma table.
    I ask to make criticism to my conclusions and a design. I never built and did not maintain plasma CNC.
  1. Mobile base for the IH: any ideas?
    By deaeni in forum Charter Oak Automation Support Forum
    Last Post: 07-30-2006, 02:25 PM
  2. Zen, CNC, and Mobile Robots
    By ToyMaker in forum RC Robotics and Autonomous Robots
    Last Post: 02-06-2005, 11:39 PM
