Hello.
I need to connect the kflop/kanalog to the pc via a long usb cable >15m.
By doing that i get disconnection problems very often.The kflop/kanalog is powered from the pc power supply, via a long 15m 4x1.5mm2 cable. Please advice the best possible practice.Should i better use a separate 5vdc isolated power supply.Will a opticaly isolated usb adapter help?.
It is very difficult to move the pc closser to the kfop/kanalog, so this should be the last solution.
