Hi there,
I made a home made router a few years ago and got a lot of use out of it. It's been gathering dust for the past 12 months and I'm looking to use it again. The spindle I use is a cheap Ozito laminate trimmer. These are $85 from Bunnings and while they work well enough they are extremely noisy. My current Ozito has died (power switch broke) so I need to replace it. I would like to get a "proper" spindle with a VFD to keep the noise down. I'd like to avoid water cooling systems if I can, though I'm happy to be convinced otherwise. I find the options for such spindles very confusing and their availability from NZ seems low. Here's a simple question:
What's an equivalent quiet spindle to, say, the Makita RT0700CX? By "equivalent" I mean it'll cut timber (pine, ply, MDF, rimu, macrocarpa) and acrylic with a similar speed. I found the Ozito can only do 2.5mm passes in most timber which makes cutting through 20mm take quite a while. Hopefully a different spindle will be gruntier.
Where do I get such a spindle from in NZ?
Allistar.
