584,863 active members*
4,918 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > HBS86H clone with Nema34 from act-motor
    Feb 2018
    8
    Is anybody using the black HBS86H from 'Act-Motor' instead of the metallic blue one from Leadshine ???
    At first I thought there was no difference but when I started with the wiring of the encoder feedback connector, I found that the order of pins is different.
    pin1 : PB- (act-motor) , EB+ (leadhshine)
    pin2 : PB+ (act-motor) , EB- (leadhshine)
    pin3 : PA- (act-motor) , EA+ (leadhshine)
    pin4 : PA+ (act-motor) , EA- (leadhshine)
    Now I am not sure, if I can trust the white printing on the case and which wire to connect to which pin.
    I contacted ActMotor but due to chinese holidays, they are not able to answer right now. So maybe somebody is out there who is using the same driver with Nema34.
    Uwe
    Nov 2004
    Re: HBS86H clone with Nema34 from act-motor
    Hi UWe,
    did you get any reply from ACT?
    I'm in the same situation, the HBS86H driver from ACT has a couple of pins ( z+/z-) that the leadshine does not have.
    I would appreciate your help
    cheers
    Giorgio
    Feb 2018
    8
    Quote Originally Posted by girogiri View Post
    Hi UWe,
    cheers
    Giorgio
    Hello Gorgio,
    Yes, ACT has sent me a picture (attachment 1). After some testing and measuring, I also completed my own wiring (attachment 2).
    Final assembly is still not completed as I am waiting for some suitable connectors from China.
    BR
    Uwe
  1. Power Supply for HBS86H with Nema34
    By digdagdigedag in forum Leadshine
    Last Post: 04-15-2020, 05:01 AM
  2. Nema34 motor wiring..
    By spiiiral in forum Leadshine
    Last Post: 01-15-2017, 08:33 PM
  3. Dual Shaft NEMA34 Stepper Motor Sale....but I only need single shaft.
    By jerseyguy1996 in forum Stepper Motors / Drives
    Last Post: 11-25-2014, 09:25 PM
  4. NEMA23 or NEMA34 closed loop stepper Motor System-Hybrid Servo kit
    By automationtechinc in forum News Announcements
    Last Post: 11-22-2012, 01:58 AM
  5. NEW NEMA34 Stepper Motor with G540 driver kit
    By automationtechinc in forum Automation Technology Products
    Last Post: 12-11-2010, 01:29 AM
