585,974 active members*
4,191 visitors online*
Results 1 to 6 of 6
    Sep 2012
    106
    Dyna Software Issue EM3116
    Hi guys, picked up a Dyna EM3116 from an auction. Worked fine after fixing a few small issues, then crashed. I was able to get software from another Dyna owner, but the versions are a little different and some functions dont work. I have version 2.0 of the 4M.exe file, and he sent me 2.2. I know its just the bad EXE since I can run one (the 2.2) in a dosbox sim and the 2.0 file will just crash it. Looks like everything else is working. does anyone have a 2.0 4M.exe file? You can check the version by opening the 4M_SYS.DAT folder with notepad, mine says 2.0 10/27/1997.
    Also once i get this running if anyone needs software (either 2.0 or 2.2) and wiring info let me know. Im also going to be working on converting from a HDD to a SD drive just like I did on my big Acramatic machine.
    Sep 2012
    106
    Re: Dyna Software Issue EM3116
    Anyone? Still looking for 2.0. I have 1.46 and 2.2 if anyone needs them
    Jan 2021
    4
    Quote Originally Posted by Third-Gen View Post
    Hello,
    I'm looking at a DM2800 with the updated controller with the color screen. Did you ever get the SD drive to work on it. Also can you program in Master cam and then load on the Dyna?
    Thank you for the help
    Nov 2006
    33
    I think I'm running 2.0, do you still need it?
    Apr 2022
    Hello there,
    Do you know if you have to configure the cmos and bios if you update the software on the controller? Seems the setting were lost on machine.
    Jul 2022
    6
    hello everyone im very new to cnc milling i bought two dm2800 with tons of parts i paid a bit for them i watched the guy bi biught them from run them with the controller i was told i could buy a laptop with windows ten and get a cad program and run them. i have found nithing that works i have the db25 cable. what do i do from here i paid 5k for the two machines and parts with 20 collets. im at a loss any help would be greatly appreciated
  1. DYNA EM3116 Mill Questions
    By jomans in forum Dyna Mechtronics
    Last Post: 08-31-2019, 06:04 AM
  2. DYNA EM3116 Mill Questions
    By jomans in forum Knee Vertical Mills
    Last Post: 10-27-2017, 02:39 PM
  3. Information on a DYNA EM3116 CNC Knee Mill
    By shoptalk00 in forum Dyna Mechtronics
    Last Post: 01-08-2012, 12:41 AM
  4. DYNA EM3116 Manuals
    By adnanahmad in forum Dyna Mechtronics
    Last Post: 08-05-2011, 12:32 PM
