I have problem with a H2o jet 50 hp pump with mechanical cables shift valve and need help
it does not seem to cycle properly , it pumps to 30k psi then after a few seconds pressure drops to 0 and shifting stops.
Then after a few seconds it sound like the shift valve kicks in and pumps up to 30 k psi then the pressure drops again.
cant get the pressure to above 30k psi
it seems to be a hydraulic problem as I have recently rebuilt all the pump HP and LP seals
I have replaced shift valve , cables , firing pins, springs.
any suggestions appreciated
Peter
