586,022 active members*
3,638 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seikis VK45 II - Seicos M3 - Error 867
    Oct 2016
    14
    Good morning,
    I have a problem with my hitachi VK45.
    Sometimes the machine gives me the alarm :
    " 867 DT 4TH axis vel. feedback disconnected "
    I don't have the 4 th axis....
    The strange fact is that i can work everyday for a month and i don't have any problem,
    and sometime i can't work for a day. The alarm appear also if the machine doesn't work , but is in standby.
    When it happens, i have to turn off the machine, wait 30min/1h and maybe i can start to work again
    What could it be?
    Thank you
    Enrico
    Dec 2009
    539
    Re: Hitachi Seikis VK45 II - Seicos M3 - Error 867
    Enrico
    did this machine ever have a 4th axis do you know?
    John
    Oct 2016
    14
    No, this machine never had the 4th axis
    E.
    Dec 2009
    539
    Enrico
    unplug and reconnect all cables on the servos to be sure they have good connection. That is my first guess; if it never had it it might have a loop connector. Simple test before we get more into it
    John
    Oct 2016
    14
    John
    I've already test every single cable from SASS11 to the spindle's inverter, everything is ok.....
    I start thinking that for 4th axis the control means "the axis" of rigid tapping ( in this case )
    I'll do more test with cable, but now i need to work. Do you know if is possible to deactivate the 4th axis?
    I must do some urgent works ( without tapping ), and then i can get more on it
    Enrico
  1. Hitachi Seiki Seicos 5117 error
    By bevins in forum Hitachi Seikis
    Last Post: 08-04-2014, 01:05 AM
  2. Can't find diameter offset screen!! - Hitachi-Seiki VK45 w/Seicos Mk2 control
    By laka in forum Uncategorised MetalWorking Machines
    Last Post: 12-04-2010, 06:10 PM
  3. Hitachi Seicos VK45
    By buck585 in forum Uncategorised MetalWorking Machines
    Last Post: 08-12-2009, 10:37 PM
  4. hitachi Seiki VK45 with Seicos II
    By Dancy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-13-2007, 09:26 PM
  5. hitachi Seiki VK45 with Seicos II
    By Dancy in forum Uncategorised MetalWorking Machines
    Last Post: 12-11-2007, 09:16 PM
