Originally Posted by
Bcarson
Hi, and thanks for the suggestions. There was no manual, I believe that it was e0, but now have removed the spindle, and some hassle to check the code, and without manual, no need. Because this is a 110 volt VFDs and spindle which is more non standard, the problem could be in some d-code maybe is set for 220 machines. The best I could hope foe here would be someone that has the 110 volt model working which is same to forward a list of their codes, and on that note, some have seen posted codes like 00.00 but I think there is a 5th digit to the left I believe, like a 4 that does not show unless they use the left arrow th see it.
Currently, I am corresponding with the seller, possibly they will ship a replacement VFD and spindle, I can see this will take some time, but it will be interesting to find out the reason. Thanks, I cannot at this time check wiring, opening box could mess warranty. Oh, when starting the spindle on the manual setting, when turning up the pot, the motor will humm for 4 seconds and then error out, but, if I assist it with a spin, it will come up to speed with no error. I have no way to see if it has cutting ability, or stall if a load were applied. Interesting situation.
