585,582 active members*
4,677 visitors online*
    Apr 2007
    4
    Exclamation Sanyo Denki Help
    I have aquired some Step-Syn stepping motors rather large ones, 3.6VDC 6.1A Unipolar 6wire 2phase 42 frame, which i intend to convert a overhead router to cnc (table),which driver and power supply would suit, as i am new to this i could do with any help, and does it mean 2phase thats 3.6v per phase and does anyone know the wiring code for these motors Thanks GD
    Mar 2012
    sanyo denki 6 wire steppers
    sanyo denki
    all electronics $14.00ea.
    6-LEAD STEPPER MOTOR | AllElectronics.com
    found the wiring diagram:
    model 103g770-1854
    pin1/red = A
    PIN2/BLUE = B
    PIN3/YELL = A-
    PIN 4/ORG = B-
    PIN5/ WHT = COM
    PIN6/BLACK = COM
    If your wiring matches this double check with ohm meter. across A and A- should be one resistance, now find the matching common, should be aprox half that( B or B- with common ) . then check the remaining 3 wires same B AND B-, NOW B or B- with remaining common.
  1. Sanyo Denki PM Driver
    By Florin in forum Stepper Motors / Drives
    Last Post: 06-25-2009, 02:21 AM
  2. Sanyo Denki BL Super
    By corydoras in forum Servo Motors / Drives
    Last Post: 02-01-2008, 12:41 AM
  3. G20 and Sanyo Denki Super-U
    By happytriger2000 in forum Gecko Drives
    Last Post: 05-20-2007, 01:24 PM
  4. sanyo denki p5 servos
    By vertcnc in forum Servo Motors / Drives
    Last Post: 09-04-2006, 11:26 PM
  5. Step-Syn from Sanyo Denki
    By tecno in forum CNC Machine Related Electronics
    Last Post: 11-10-2003, 01:06 AM
