585,667 active members*
3,904 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Looking for a manual rotation fixture for 3-axis CNC
    Jan 2018
    17
    Hi
    We're looking to purchase a manually operated rotation fixture - ie.
    • put a piece of wood inbetween 2 ends;
    • set the rotation degrees (we'll probably just use increments of 90deg - eg. 180deg is the opposite side)
    • wood must be clamped tight in fixture (for obvious reasons)
    • once job is done, change rotation & load job for the new side
    I've looked online & i'm not even sure if this thing exists or maybe i just don't know what it's called as i've found nothing.
    I've found motorised components to make a 4-axis machine but we're after something manual & not complex.
    The boss will be purchasing a 6 head 3-axis at some stage so want something that could be used for this also.
    I thought this would be a fairly common fixture component as it's useful as not only as a stock fixture but also for easy & cheap(?) multi-side milling.
    Does this tool/thing exist?
    Cheers all
    Quote Originally Posted by boom-shanka View Post
    Hi
    Cheers all
    Spindexer with tailstock from tormach.
    About $100. They allow up to 1 degree increments.
    Spin indexer.
    Jan 2018
    17
    Re: Looking for a manual rotation fixture for 3-axis CNC
    Quote Originally Posted by AMG Guitars View Post
    Spin indexer.
    This looks fantastic, thank you.
    I'm just not sure how a piece of wood would fit to the rotation end - how would an inserted collet hold the wood piece?
    Dec 2017
    77
    You could get a 4-jaw chuck with 5C arbor, instead of a collet.
    May 2006
    803
    Do you possible need a professional production tooling and fixturing design expert?
    Show us the part..
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. Replies: 19
    Last Post: 06-07-2016, 05:54 AM
  3. Rotation along the y axis?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 07-09-2010, 05:27 PM
  4. X axis to A rotation
    By quemast in forum G-Code Programing
    Last Post: 06-18-2006, 02:36 AM
