585,763 active members*
4,398 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Lathe > Conversion of turn wizards code for a slant bed tooled lathe
Results 1 to 7 of 7
    May 2009
    98
    I have a CNC lathe with tooling running behind the spindle on a slant bed. Is there a macro to use with the turn wizards to change the code for the rear side tool approach?
    Scott
    Dec 2013
    5717
    Re: Conversion of turn wizards code for a slant bed tooled lathe
    There is no difference between the slant bed and a normal bed lathe. Picture standing at the end of the lathe and rotating the carriage around the spindle axis. The cutting geometry is the same as is the axis move directions.
    Jim Dawson
    Sandy, Oregon, USA
    May 2009
    98
    I agree to a point, but the movement in front is right to left. If you spin around it needs to be left to right when machining from the same end. I cannot get the set ups to accept that type of tool movement. I get error messages. Am I still missing something?
    Thanks for your help.
    Scott
    Dec 2013
    5717
    I'm not sure I understand what you are saying. Z minus is still towards the chuck and X minus is still towards the spindle centerline. Depending on how you set your tools, the spindle direction could be CW or CCW.
    Maybe I'm missing something here.
    Jim Dawson
    Sandy, Oregon, USA
    May 2009
    98
    Thanks again Jim. After I replied to your answer I thought about it more and agreed you had to be right. I went to wizards and did an OD arc. All the roughing operations ran as you would expect. Then at the very end of the code the actual arc to clean up the piece runs backwards iinto the work rather than away. I remember now I figured this out once and changed the arc command to make it work. It is screwy this way with facing as well. Making the taper the wrong direction.
    Dec 2013
    5717
    Quote Originally Posted by Scott Pancheau View Post
    ......... I remember now I figured this out once and changed the arc command to make it work. It is screwy this way with facing as well. Making the taper the wrong direction.
    That is very strange. I would expect that if it did the roughing cuts correctly then it would also do the cleanup in the correct direction. Now I'm really confused.
    Jim Dawson
    Sandy, Oregon, USA
    May 2009
    98
    I haven't got back to the lathe yet but I remember if it is a go2 arc you have to change to go3 and vice versa. Thanks again, I think I can play around now and make myself some notes and it will be workable.
  1. Slant turn
    By W.M.E in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-05-2018, 08:42 AM
  2. Replies: 2
    Last Post: 05-03-2016, 06:30 PM
  3. Mazak Slant Turn 30 ATC lathe
    By willsilvers in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-25-2012, 11:09 AM
  4. 4 axis G-code Wizards available
    By Legacy CNC in forum News Announcements
    Last Post: 06-25-2008, 10:02 PM
  5. small production run - live tooled lathe and mill prolly required
    By Vitamin-E in forum Employment Opportunity
    Last Post: 02-22-2006, 03:12 AM
