Hello. Today the first day my 4th axis is working exactly.
I had create indexed toolpathes from 4 sites with clipping planes in the middle of the part. From two of the 4 sites I go deepeer as the middle and in roughing toolpath has a stock for finishing of 0.2mm
The part i will mill is to the right the same measurement as the left site from zero but on one site madcam let more stock material as 0,2mm finishing distance.
later, in finishing madcam cuts this 2mm and also the 0,2mm in one cut but before it works on this site the little finishing Cutter runs in highspeed between this matrial and brake.
Why does madCAM calculate one site correect to the 0.2mm finishing hight but not te other site?
thank zou, Ron
