586,009 active members*
4,851 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Rotary 3-phase converter
    Jan 2011
    129
    I have a rotary phase converter that’s capable of running a total of 20 hp. According to the data plate, although it will handle a total of 20 hp, it will only start a maximum of a 7 1/2 hp three phase motor.
    Y
    My dilemma is I want to run a milling machine that has a 15 hp spindle motor.
    Considering the 7 1/2 hp limitation, they have to be considering motors that start under load, like compressors or pumps, etc.
    Since my spindle motor would never start under any load I’m wondering if I could use this particular rotary phase converter on the milling machine.
    Does anyone have any experience relative to my question?
    Chuck
    Dec 2013
    5717
    Re: Rotary 3-phase converter
    Based on my limited experience with RPCs I'll say that it should work fine. I've had no problems starting a 10HP spindle motor on a 15HP RPC. Having said that, the spindle is operated by a VFD so it doesn't start across the line, ramp up is about 1.5-2 seconds or so.
    If you have a VFD or other controller on your spindle I would say there is no problem.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2011
    129
    Thanks Jim, I will give it a try.
  1. Rotary Phase Converter
    By moonman5 in forum Phase Converters
    Last Post: 03-20-2017, 06:13 PM
  2. Rotary phase converter question
    By Ron Thompson in forum Phase Converters
    Last Post: 12-10-2016, 10:57 PM
  3. 3-Phase Quality From Rotary Phase Converter
    By yoopertool in forum CNC Machine Related Electronics
    Last Post: 04-01-2015, 04:44 AM
  4. rotary phase converter
    By fastleather in forum Want To Buy...Need help!
    Last Post: 12-15-2010, 02:40 PM
  5. 760-22 with rotary phase converter?
    By tstom in forum Bridgeport / Hardinge Mills
    Last Post: 03-03-2008, 07:34 PM
