I'm almost done with a homemade CNC machine that I've been working on. I've got two final things to work through to finish up and would definitely appreciate some help. My Nema 34 Servo motors are buzzing/vibrating any time they have power. It doesn't matter whether the axis are moving. Also, I have a Huanyang 7.5kW inverter and a 4.5 kW air cooled spindle. As soon as I press Run/Test it faults out within a second with an error code E.OC.A (Error.Over Current during Acceleration). I can't figure out what's causing this. Mach 3 is my controlling software. Any ideas? Thanks for any help you can offer.
Here are the components of my machine:
Nema 34 KL34-180-90 1125 oz/in Servo Motors, Geckodriver G320x drivers, CUI AMT102-V encoders, KL-7220 72 volt power supply https://www.automationtechnologiesin...4-axis-nema34/
C10 Bi-Directional Breakout Board
https://www.automationtechnologiesinc.com/products-page/motion-controllers/c10-bidirectional-breakout/
Huanyang 7.5kW Variable Frequency Inverter (using single phase 220v power)
https://www.automationtechnologiesinc.com/products-page/cnc-spindle/variable-frequency-drive-inverter-vfd-7-5kw-10hp-34a/
4.5kW KL-4500 spindle
https://www.automationtechnologiesinc.com/products-page/cnc-spindle/4500w-air-cooled-spindle/
