Hello
I have a problem with a machine that 2 weeks ago hit with the spindle the arm of the magazine.
As a result of the Z-hit, the thermal relay jumped.
I checked everything in the tool magazine that is still in position.
But the problem is that the spindle is now 10 mm behind in the tool change position.
The solution would be to move it 10 mm forward by changing the parameter that holds that position.
Unfortunately I have not worked with heidenhain so far and do not know which parameter should be changed and how to do this.
So if someone in the forum has more experience in NC heidenhain, I'm asking to help me please with this parameter and how to change it.
Thank you !
