584,849 active members*
3,854 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Trying to build a tool list in technology database
    Mar 2018
    Exclamation Trying to build a tool list in technology database
    Does anyone have any helpful tips with building a tooling database within CamWorks technology database. I have started building some endmills into it and I am wondering if there is a way to move the order of them around so they will go in order of tool numbers I have. Or is there a way to copy or move tool data lines so I could manually insert new lines or put them into order?
    Nov 2008
    15
    Re: Trying to build a tool list in technology database
    Good Morning. You may be confusing a tool database with machine tool cribs. The tools you build via Solidworks or some other CAD program can be put in your tool database and will go into order after the last tool in the database that comes with CAMWorks. Tool numbers are then assigned when you build a tool crib for a particular machine. Not sure I am explaining that well... but, the "number" in the tool database is for database processing needs. You can build and modifiy tool cribs for your machine and assign what ever numbers you want.
    Mark
    Mar 2008
    638
    If you right click on the first box showing the diameter, you can sort smallest to largest, etc... (edit: this is in the Technology Database not the tool crib)
    Mar 2018
    Quote Originally Posted by Thrasher View Post
    Mark
    Ok, thanks for the info!
  1. Tool Management in HSMAdvisor Tool Database
    By zero_divide in forum News Announcements
    Last Post: 12-07-2015, 06:01 AM
  2. tool database
    By single phase in forum Hypermill
    Last Post: 10-22-2013, 01:41 AM
  3. Tool database
    By Like2Trike in forum Hypermill
    Last Post: 12-15-2011, 03:31 PM
  4. New V12 SQL Tool Database
    By Mike Mattera in forum EdgeCam
    Last Post: 05-20-2008, 04:43 AM
  5. tool database 5.2
    Last Post: 11-15-2007, 08:30 PM
