585,948 active members*
3,931 visitors online*
Page 1 of 2 12
Results 1 to 20 of 35
    Mar 2018
    6
    6040 CNCEST USB problems
    Hey All,
    Connected everything like it should installed Mach3 and put on the CNC openend the Mach3 software it says driver loaded but nothing works or responds.
    I did set the config as it should (double checked), still nothing.........
    No drivers cd or Manual was given, took a lot of searching the internet too find anything like plugins but non worked for me.
    Can someoone please help me i really want too enjoy my CNC. (Pic above is my USB card)
    Gr Mike
    Jan 2007
    626
    Re: 6040 CNCEST USB problems
    Same board?:
    https://www.amazon.ca/Aluoflower-100.../dp/B0759KP1CV
    There appears to be a driver for it out there somewhere....
    try googling the board part number?
    A U-Tube video:
    https://www.youtube.com/watch?v=uaHiLasUANs
    Steve
    Mar 2018
    6
    Thanks, a member send me the link to the files and it works like a charm....thanks again for the help ....now figuring everything els out.
    Mar 2018
    Hi Mike,
    Same situation on my side.
    Could you share the link and driver files you mentionned ?
    thank a lot !
    Antoine
    Mar 2018
    6
    https://madexp.com/2018/01/01/cnc-3020-usb/
    this should be it.
    Quote Originally Posted by aauffret View Post
    Hi Mike,
    thank a lot !
    Antoine
    Dec 2018
    4
    Hi.
    Could you send me the files please.
    King regards.
    James
    Dec 2007
    25
    Still trying different things...
    Quote Originally Posted by hengrave View Post
    Hi.
    James
    Which files?
    Dec 2007
    25
    Hi.
    King regards.
    James
    James-
    Figured it out yet?
    I have: PM me if you need help.
    -Christian
    Not sure if this is where to start, but it seems that many are seeking files to get there 6040 CNC to talk with their PC. Same issue. No connection. Just got this thing put together and cannot get it to do a thing?
    Jan 2007
    626
    Quote Originally Posted by JohnLeslie View Post
    Did you see post #5 in this thread?
    There's a link to a page with some info on it.
    Basically, you need to copy a 'plugin' ( for YOUR motion Card ) into your Plugin Folder in Mach 3, as well as having Mach 3 set up correctly.
    The Supplier SHOULD have given you a CD or a link where to find the file, but thats not always teh case.
    The file will be a "dll' file.
    Feb 2009
    6028
    My 6040 with USB uses the same RNR dll, I did have issues at first with loosing the USB randomly, then switched the USB cable to a heavy shielded one, never had a hiccup since.
    https://www.amazon.com/DTECH-10ft-Ca...18-spons&psc=1
    Sep 2010
    26
    I also tried with USB cable to a heavy shielded (as in the amazon link) but the same problems.
    USB Chip STM32F103.
    and installed his driver. In Device Manager, I deleted the PCI driver.
    Now he works much better but he is not good yet.
    Hello, can you share the files im having the same problem
    Apr 2018
    Hi Mike!
    I bought the same CNC, but another size (6040) and seller didn't sent any manuals, software or drivers. Can you share all this files with me?
    Regards,
    Igor
    Jul 2019
    Quote Originally Posted by MHE123 View Post
    Hi Mike!
    Regards,
    Igor
    I just bought the same CNCEST 6040 USB version with 1.5kw spindle
    can you or anyone help
    I am new to cnc and I expected to have some support from the seller
    thanks
    Dec 2007
    25
    Quote Originally Posted by gcpcnc View Post
    I am new to cnc and I expected to have some support from the seller <<<"HA HA HAAAA...ya right"
    thanks
    If you have the RED USB board shown at the top of this post, this is the driver which will need to be copied into the \MACH3\Plugins directory:
    https://drive.google.com/open?id=1J7...cAn2oyuDmouP2U
    Dec 2007
    25
    Also need to copy this file https://drive.google.com/open?id=1Fx...82oOo_nj0Gq1JK
    to the \MACH3 directory for the proper settings.
    -Christian
    Sep 2010
    26
    Thanks Christian.
    Do you know what .dll for this BOB?
    RnRMotion.dll not work.
    Jan 2007
    626
    Is this the same board?
    If so, RnR motion .dll should work.
    Attachment 424140
    I found the Manual here
    https://ncmaster.com.au/ncmaster/Mac...Breakout-Board
    Dec 2007
    25
    Quote Originally Posted by darkoford View Post
    Thanks Christian.
    No, but look on aliexpress or Taibao.com (might take VPN/translation).
    Do a search for USB BOB on google and then visit from where the photo came, sometimes works.
    -Christian
Page 1 of 2 12
  1. 6040 limit switch problems
    By wdp67 in forum Chinese Machines
    Last Post: 11-28-2017, 04:30 PM
  2. cnc 6040 alu problems
    By donminion in forum Chinese Machines
    Last Post: 10-14-2014, 08:55 PM
  3. CNC 6040 with 3 D head Shows problems
    By RodMcM in forum Chinese Machines
    Last Post: 02-04-2013, 01:33 AM
  4. CNC 6040 AND VFD PROBLEMS
    By justy22 in forum Phase Converters
    Last Post: 07-04-2011, 12:49 AM
