Originally Posted by
tmd019
I am trying to order three sets of LoveJoy couplers to connect out milling table to our stepper motors. Does anyone know the max or typical RPM which a 200 oz-in stepper motor will run? We need to know this so we can order the correct coupler.
Tom
http://surpluscenter.com/sort.asp?UI...s&keyword=PSF3
Here, try this page. I have used these several times over, now. Tough as nails and cheap.
I know that 600-800 RPM will be easily achievable, but in order to really tell you, the voltage being used is helpful as well.
Easiest solution? just follow the link, get 1/4" halves for each motor, and whatever bore size halves that fit your screw on the mill. Don't forget the rubber coupling.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
