586,009 active members*
4,921 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Unsure About Running Stepper Motors
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Dec 2006
    40
    Quote Originally Posted by Torchhead View Post
    Go over to the Electrical Engineering Dept (I KNOW they have one at TECH!) and find a lab assistant that knows how to read a schematic and use a scope and pulse generator.
    But it's a HobbyCNC board without schematics. WHATEVER WILL THEY DO?? *snicker*
    There is a lot more to a drive than just getting voltage to it. You have to troubleshoot this one thing at a time. There are too many variables right now. First the motor drive has to be confirmed as working, then setup the software and finally the motors and mechanics. The fact the motor does not lock when you apply power is not a good sign. Even with no Step & Dir signal most chopper drives will lock the rotor on the motor at power up.
    I would also recommend they see if they are getting signal from their parallel port INTO the drive. As you said though, the drives not locking is usually a tell tale sign you've got problems with the driver IC's.
    I am curious to know if they powered on the driver board without any motors hooked up to it?
    PS stay out of the AG dept. Those people will HURT you! (:-)
    +1 :-)
  2. #22
    Apr 2007
    17
    If the motors don't lock up when the board is powered up, then the board is not working, or the steppers are wired wrong. You might want to contact Dave, or join the HobbyCNC support forum at Yahoo if you can't get the help you need here.
    Also, if you're trying to run TurboCNC in any OS other than Win98 or earlier, it will not work at all. Although it will work in Win98, it won't work well. Best to run it from DOS directly.
    I can't seem to find the HobbyCNC support group on yahoo. Could someone please send a link to the site?
    Tom
  3. #23
    According to their website:
    A link to this support group will be provided by us via your PayPal order SHIPPING acknowledgement.
  4. #24
    Apr 2007
    17
    Love Joys??
    I am trying to order three sets of LoveJoy couplers to connect out milling table to our stepper motors. Does anyone know the max or typical RPM which a 200 oz-in stepper motor will run? We need to know this so we can order the correct coupler.
    Tom
  5. #25
    Mar 2006
    759
    Quote Originally Posted by tmd019 View Post
    Tom
    http://surpluscenter.com/sort.asp?UI...s&keyword=PSF3
    Here, try this page. I have used these several times over, now. Tough as nails and cheap.
    I know that 600-800 RPM will be easily achievable, but in order to really tell you, the voltage being used is helpful as well.
    Easiest solution? just follow the link, get 1/4" halves for each motor, and whatever bore size halves that fit your screw on the mill. Don't forget the rubber coupling.
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
  6. #26
    Apr 2007
    17
    LoveJoy
    Tom
  7. #27
    Apr 2007
    17
    Mach3
    If you're using XP, try Mach3. watch the setup videos at www.machsupport.com
    But get the motors to lock up first.
    I have downloaded the Mach3 demo program and I was wondering what kind of initial setup will be needed in Mach3 before I can start running my g-code.
    Tom
  8. #28
    Tom
    Setup the port address and the pins, and that should be it. The video I mentioned earlier explains it very well.
  9. #29
    Apr 2007
    17
    can't play videos
    Any ideas about how to run the videos on the mach support website?
    Nothing I do seems to run these videos.
    Tom
  10. #30
    Dec 2006
    40
    They are shockwave flash videos....you have to have the flash player installed to view them.
    Its a free download from macromedia.com's website.
Page 2 of 2 12
  1. First post.... unsure??
    By flashmeister in forum Uncategorised CAM Discussion
    Last Post: 05-26-2007, 05:44 AM
  2. Stepper running choppy
    By Smackre in forum CNC Machine Related Electronics
    Last Post: 02-15-2007, 03:36 AM
  3. running stepper at 12v
    By mikejkd in forum Stepper Motors / Drives
    Last Post: 05-24-2005, 07:42 PM
  4. Running 2 motors on the same axis
    By xairflyer in forum Stepper Motors / Drives
    Last Post: 03-07-2005, 01:31 PM
  5. Replies: 1
    Last Post: 11-12-2004, 05:28 PM
