585,764 active members*
4,076 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Unsure About Running Stepper Motors
Page 1 of 2 12
Results 1 to 20 of 30
    Apr 2007
    17
    I am a Mechanical Engineering senior at Louisiana Tech University, and our group
    chose to build a portable CNC machine for our senior design project. We have chosen to convert a mini drill press and a milling table into a 3-axis milling machine. We have finished construction of our driver board, downloaded TurboCNC 4.01, and we are trying to gain movement in the stepper motors. I am unfamiliar with TurboCNC. I have been trying to output G-code from TurboCNC to run the stepper motor, but nothing seems to work. If someone could give me some advice, it would be a great help.
    Tom
    PS: All voltages and currents on the driver board have been checked and are correct.
    Jan 2006
    357
    I use mach3 so I am not familiar with turbocnc but have you setup your ports and pins?, You also have to setup your steps per inch. When you turn on the power supply do your motors lock up?
    Jul 2005
    668
    You say all currents and votages on the drive are correct, but do you know that the drive is working correctly? You can apply step and direction signals to confirm this.
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
    Apr 2007
    17
    Well first of all, I only have my X-axis motor connected at the moment. When I turn on the power, I can still turn the stepper motor shaft with me hand.
    Is there a freeware version of Mach3 or Mach2 out there?
    Tom
    Apr 2007
    17
    How would I go about applying a single step to the motor without TurboCNC?
    Tom
    Jul 2005
    668
    Quote Originally Posted by tmd019 View Post
    Tom
    You can get the free trial version that will do everything you need.
    Steve
    Jul 2005
    668
    Tom
    Apply ground to the dir signal and use a function generator with a 5v square pulse as the step signal.
    However, if you can turn the shaft with your hand after you apply power the drive is probably not working.
    Steve
    Mar 2004
    1804
    Are you trying to run Turbocnc in a dos window or have you actually booted to a dos prompt? Turbocnc will NOT acess the prot properly in a dos window!
    As stated above, you have to configure the port pins and possibly you have to "enable the drive"
    Are you running a break out board (bob) or wiring directly to the driver and what driver are you using?
    Art
    AKA Country Bubba (Older Than Dirt)
    Apr 2007
    17
    Quote Originally Posted by Bubba View Post
    Can someone tell me how to configure my port pins?
    I am also wiring directly to the driver.
    I'm sorry if I am asking simple questions but I am very new to this entire process.
    Tom
    Jul 2005
    668
    Tom
    Take it one step at a time. Since you built your drive, make sure it works.
    Steve
    Apr 2007
    17
    fan runs
    When I turn the power on, the cooling fan will start to run. Because of this, I am fairly certain that my power connections to the driver board are correct. But I am guessing that my problem might be some other place on the board.
    Any suggestions?
    Tom
    Jul 2005
    668
    What drive and motor are you using?
    Steve
    Apr 2007
    17
    We ordered the 200 oz-in 3 axis package from HobbyCNC.com. I will post the link below that states all of the components used.
    http://hobbycnc.com/hcncpropkg.php
    Tom
    Jul 2005
    668
    I think you will get better help in the hobbycnc forum:
    http://www.cnczone.com/forums/forumdisplay.php?f=240
    Steve
    If the motors don't lock up when the board is powered up, then the board is not working, or the steppers are wired wrong. You might want to contact Dave, or join the HobbyCNC support forum at Yahoo if you can't get the help you need here.
    Also, if you're trying to run TurboCNC in any OS other than Win98 or earlier, it will not work at all. Although it will work in Win98, it won't work well. Best to run it from DOS directly.
    Apr 2007
    17
    Well for starters, I am running Windows XP. I guess the next step is to try and run in DOS directly. I am more worried about my motors not locking up when power is applied. I guess I will try to look at the instructions again, and reconnect the stepper motor.
    Tom
    If you're using XP, try Mach3. watch the setup videos at www.machsupport.com
    But get the motors to lock up first.
    Apr 2007
    17
    Do you know of a trial or freeware version of Mach3 out there?
    Tom
    Mach3 is free for up to 1000 lines of g-code. Just download and install and you're good to go. Any version should be fine, but you'll probably be safest with the current lockdown version from www.machsupport.com
    Jul 2005
    2415
    Go over to the Electrical Engineering Dept (I KNOW they have one at TECH!) and find a lab assistant that knows how to read a schematic and use a scope and pulse generator. There is a lot more to a drive than just getting voltage to it. You have to troubleshoot this one thing at a time. There are too many variables right now. First the motor drive has to be confirmed as working, then setup the software and finally the motors and mechanics. The fact the motor does not lock when you apply power is not a good sign. Even with no Step & Dir signal most chopper drives will lock the rotor on the motor at power up.
    PS stay out of the AG dept. Those people will HURT you! (:-)
Page 1 of 2 12
  1. First post.... unsure??
    By flashmeister in forum Uncategorised CAM Discussion
    Last Post: 05-26-2007, 05:44 AM
  2. Stepper running choppy
    By Smackre in forum CNC Machine Related Electronics
    Last Post: 02-15-2007, 03:36 AM
  3. running stepper at 12v
    By mikejkd in forum Stepper Motors / Drives
    Last Post: 05-24-2005, 07:42 PM
  4. Running 2 motors on the same axis
    By xairflyer in forum Stepper Motors / Drives
    Last Post: 03-07-2005, 01:31 PM
  5. Replies: 1
    Last Post: 11-12-2004, 05:28 PM
