starting to find more and more issues around this 31i panel that i have never encountered on older fanuc panels when writting custom macro cycles.
So in short i have created a custom macro G13 cycle to allow me to use some proven Haas programs we have had in use for a no. of years to save rewriting the same programs again.
so at present im having to call the program via:
ie:
G65 P9013 I50. Z-1. D20 F500.
so at present still have to edit up the HAAS pgms instead of calling
G13 I50. Z-1. D20 F500.
i have gone down the usual procedure of setting the G-code name into parameter #6053 to call pgm O9013
but it refuses to accept the G13 code...
i have also tried this as another no. so called it O9019 and used #6059 for the G13 call again it will not accept the command.
Has something else been changed within the 31i software over the older 16M/18M/21i panels that i have not encountered until now?
