Hi, I require the schematic diagram to connect the DC motor to Gettys drive Type no. 11.10.10.74.
Anyone having it please give it.
Getty's has been taken over a few times since their production of DC motors around the '60's '70's .
The last communication I had with them was through American Precision Industries in 1997. (API Getty Inc).
But the info I wanted was made by them in 1978 and they were not retaining anything that was obsolete at the time.
The Engineer i contacted has probably long retired.
Do you just need the hook-up connections?
Al.
Albert E.
Is the motor of the same vintage as the drive?
As getty's DC drives usually had a tach input which is almost never used in today's drives.
IOW are these an original Motor/drive pair?
Al.
Albert E.
Yes, it has a tach input.
Does the motor?
Al.
Albert E.
yes
I assume the inputs are not labeled?
Can you post a Pic, see if I recognize it?
Al.
Albert E.
Terminals are marked, but not sure of some terminals. Could you explain please
Is it possible for you to provide me with your phone no. to call & discuss.
I am in Canada & my phone no is 9056010042
Other than trying a few of the obvious connections, I would be inclined to go with a more modern drive such as a A-M-C or similar drive and disregard the tach.
Al.
Albert E.
Thank you.
