585,996 active members*
3,850 visitors online*
    Mar 2018
    Control alarms
    I have a Hitachi Seiki Hi Cell 23 ii with a Seicos 10L control. I purchased this machine used and the back up batteries were dead I replaced the batteries and have the following alarms 699 directory broken, 1421 VID starting error, 1281 X ASC disconnected, 802 PC all Sum check error. Can you help me reboot this control. Thanks Bob
    Dec 2009
    539
    Re: Control alarms
    Bob
    are you still having troubles. Should be no big deal to get back online- let me know!
    John
    Mar 2018
    Re: Control alarms
    Quote Originally Posted by shas595 View Post
    Bobare you still having troubles. Should be no big deal to get back online- let me know!John
    Yes it is still down same alarms. Would appreciate any help you can provide. Bob
    Dec 2009
    539
    Re: Control alarms
    Bob
    sent you a PM - take a look - there is some info ill send you
    John
    Aug 2013
    11
    I have same problem on directory broken alarm 699. All function manually is ok, only for edit program and command through MDI mode can not be done. Need help please
    hary
  1. Prodis Fanuc oi-mc control all alarms
    By MADJ in forum Vertical Mill, Lathe Project Log
    Last Post: 03-11-2016, 03:53 AM
  2. Okuma lathe with fanuc control Z alarms
    By rob jerico in forum Fanuc
    Last Post: 07-18-2013, 06:22 PM
  3. Seiki-Seicos LII Bubble memory Alarms --- Help on recovering from alarms 104,144,105
    By AZTEXAN_MIMXII in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2013, 08:59 PM
  4. Replies: 1
    Last Post: 02-17-2013, 07:46 PM
  5. matra mill alarms fanuc om control alarm code 1004
    By dancro316 in forum Community Club House
    Last Post: 02-17-2013, 03:59 AM
