585,758 active members*
4,572 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > Ethernet Smoothstepper to G201X Geckodrive
    Apr 2017
    6
    So ordering parts for my project I hit a little snag. I have a computer with windows 10 already. I already have 1800oz motors and my G201X gecko drives. I inquired about a ESS and the sales person said I would probably need a break out board between the ESS and gecko drive, but they would send my email to tech support and they could tell me for sure. Sent another email a few days later saying I still need to know if I can use their device or not. Well its been silent so far and I already have my parts and would like to start playing with things. So from what I understand a breakout board just takes that ribbon cables and routes the pins to screw terminals. I don't see why with a diagrams I couldn't just cut the ribbon cable and land the wires directly right or is there a break out board that makes this all stupid simple?
    Re: Ethernet Smoothstepper to G201X Geckodrive
    Good breakout boards add a lot of additional features.
    #1 is isolation, which can prevent damage to the ESS.
    They can add relays, speed control, and other features.
    At a minimum, I'd use one or two of the $10 5 axis boards from Ebay. If you want a really good breakout board, get an MB2 from CNC Room.
    Jun 2011
    68
    Check these breakout boards out.....
    PMDX.COM - Products for CNC and motion control applications
    good luck,
    Stuart
    Apr 2017
    6
    Thanks, I like how the PMDX-134 cleans up the drives. so if I get a PMDX-134 and a lph26 cable I should be able to make something move I believe.
  1. Smoothstepper ethernet or Xhc Mk4-v 4axis ethernet?
    By Nleo22 in forum Want To Buy...Need help!
    Last Post: 09-08-2017, 11:37 PM
  2. Want to buy used Ethernet SmoothStepper
    By Azalin in forum Want To Buy...Need help!
    Last Post: 03-28-2016, 09:33 AM
  3. help smoothstepper ethernet!
    By Cam4ge in forum SmoothStepper Motion Control
    Last Post: 04-30-2013, 11:58 PM
  4. Smoothstepper (ethernet)
    By t300 in forum Novakon
    Last Post: 09-08-2012, 02:43 AM
