585,660 active members*
3,225 visitors online*
IndustryArena Forum > CAM Software > Mastercam > X7 tries to double save Gcode
    Nov 2012
    162
    I 'm haveing a problem where X7 tries to double save Gcode then only posts the first tool.
    I have a HASP type setup will full Mill and lathe features.
    This has happened before and required a full reinstall of the program which is a pain. Is there an easier way to fix this?
    This time it happened when I tried using the break Through option while drilling and if I remember correctly, last time was was using the same feature. (Might be my imagination tho!)
    The part is a simple one hole with spot drill first.....same thing I do regularly.
    Thanks again for the help guys!
    Nov 2012
    162
    Re: X7 tries to double save Gcode
    Quick update....
    I named the file
    partnumber 9/16 hole and it messed up. Renamed the file and rebooted and did the same thing.
    After I deleted the files (both g code and part file) and rebooted the computer, and ran a quick file scan on the hard drive, I was able to redraw and recode the part correctly.
    I guess the "/" was causing the problem.
    Feb 2018
    59
    we had this same thing happen a few years back,,,
    Apr 2003
    3578
    Select all ops and then right click in the toolpath manger and go to the edit selected operations then Change NC name and close and post.
    Cadcam
  1. Replies: 6
    Last Post: 02-01-2017, 04:54 PM
  2. CNC Router with Double Spindles and Double Rotary
    By WINNI-DI in forum Chinese Machines
    Last Post: 12-01-2015, 03:01 AM
  3. Replies: 0
    Last Post: 06-26-2013, 08:17 PM
  4. Double sided PCB with pcb-gcode video
    By jepetera in forum Videos
    Last Post: 02-19-2011, 01:06 PM
  5. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
