585,938 active members*
3,682 visitors online*
Results 1 to 6 of 6
    Feb 2018
    8
    PlasmaCam on wheels
    Has anybody ever put casters (wheels) on their plasmacam?, any pictures?
    Mar 2018
    4
    Re: PlasmaCam on wheels
    Here's an example and idea of what you could do with the PlasmaCam DH4. This type of table is designed to sit flat on a perfectly level floor and if the floor is not level shimming is required.
    The 4' table and the Sampson table as well is flexible enough that it needs a four corner lift to move it or 3 lifts on each side of the Sampson table to prevent twisting of the frame.The dolly in the pictures plugs in to a 2" socket on each corner of the 4' table and is removed after moving the table.
    I'm not here to promote these but simply to give folks a rough idea of what they can do. We have sockets on every heavy piece in the shop and use the same adjustable dollies on most everything.
    I can tell you from experience that the PlasmaCam table stays in place and cuts best when the legs are solid on the floor and NOT on casters. Hope this helps...
    Regards, --Paul
    Feb 2018
    8
    I made a cart with 6 inch casters and 2x2 x 1/4 angle iron, the plasmacam sits in it solid and square,
    Jun 2018
    4
    Yep, I did a similar thing as 527john with rolling frame, plus added a pan for my plasma and consumables. A big help was also adding adjustable mounting points so if needed, I could take-up any floor imperfections. I’ll try to get some photos posted one of these days. Also did a water pan, about 10” deep, that made a big difference in adding rigidity, made a huge difference in reducing dust too, but to that extent, it is a lot of extra work for an excellent return, so a good project to pre-plan IMO.
    Jun 2018
    4
    Nov 2010
    177
    My DHC2 4x4 is on four wheels with NO frame connecting the lower legs. It doesn't seem to affect the machine at all. I have built my own rail riser system for it. If you are interested, you can do this also, for about $1,400.00
    Joe
    https://youtu.be/Klc1zRpfHu8
  1. Where to buy Vee Wheels
    By ajclay in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-11-2014, 11:42 PM
  2. need help with fan wheels
    By birdadre in forum Want To Buy...Need help!
    Last Post: 07-08-2008, 08:47 PM
  3. ULS wheels
    By Jim Huston in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-19-2006, 04:55 AM
  4. ? about jog wheels
    By mdreitzusa in forum Benchtop Machines
    Last Post: 05-18-2006, 09:49 AM
  5. skateboard wheels for vee wheels...
    By lurch in forum Linear and Rotary Motion
    Last Post: 10-02-2005, 05:10 AM
