585,752 active members*
3,837 visitors online*
IndustryArena Forum > CAM Software > SheetCam > mach 4 plasma post processor
    Jan 2014
    28
    I have mach 4 plasma with vital system arch pro screen with sheet cam the post processor that works is the mach 3 the others don't seam to work nether does the vital system one
    my problem is I have en engraver in the plate marker tool I need to delite the M3 M5 command so it wont fire my torch with the spindle commands
    I can disable it in mach because it take my THC off line when going from engrave to a plasma cut on the same layout im almost there
    every thing works fine except torch fire win the plate marker tool using m3 m5
    Jun 2004
    6618
    Re: mach 4 plasma post processor
    Not sure what the correct way to do it would be, but short term, you could use coolant on/off commands operate the engraver relay.
    Lee
    Jan 2014
    28
    its not the engraver I have a problem with I have an out put programed with over ride switch on screen works fine in mach 4
    I just need to remove the M3 M5 spindle on command in the plate marker tool. so it wont fire my torch
    I cant switch it off because when I switch to the torch it has to work to make the torch cuts
    every thing works fine except the spindle command in the plate maker I using a hilcon controller with the arch pro screen it uses the spindle on for torch control
    if I change it ill have other tool problems wanting to use the m 3 m5 commands
    the best way is I need a plate maker tool with no m3 m6 in it ill be good to go
  1. post processor for mach 3?
    By njitnjau in forum EdgeCam
    Last Post: 09-26-2019, 04:28 AM
  2. Post Processor for Mach 3 Plasma Table
    By skygizmo in forum Autodesk
    Last Post: 02-23-2017, 12:21 PM
  3. wanted post processor from sheet cam to mach3 and mach 4 plasma
    By lkigam in forum Post Processor Files
    Last Post: 05-28-2016, 08:29 AM
  4. Mach 3 Post Processor goes where????
    By USMCCNC in forum G-Code Programing
    Last Post: 06-15-2010, 06:17 PM
  5. Mach 2 Mach 3 Post Processor
    By IntarisiaQ4 in forum Australia, New Zealand Club House
    Last Post: 10-17-2009, 11:50 PM
