584,854 active members*
4,239 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > 410PA ALZMETALL Baz 15 Problem it does not enable axes feed HOLD
    Hello
    Need Help
    Machine Alzmetall Baz 15 it does not enable axes Control Heidenhain 410PA
    Problem Feed HOLD
    Emergency stop safety relay is on. -> OK
    Safety door safety relay is on. -> OK
    E/R Modul is active yellow LED -> OK
    MP10 for axis on -> OK
    Attachment 388846
    Attachment 388848
    PLEASE HELP
    Oct 2017
    4
    Check limit switch on end positions.
  1. different feed rates for different Axes
    By looking9 in forum G-Code Programing
    Last Post: 03-12-2013, 04:52 AM
  2. Feed Hold problem
    By pit202 in forum Haas Mills
    Last Post: 07-30-2010, 07:53 AM
  3. Feed Hold Problem
    By metx in forum Fanuc
    Last Post: 01-30-2009, 05:10 PM
  4. Feed Hold
    By HelicopterJohn in forum Haas Mills
    Last Post: 04-25-2008, 03:57 AM
  5. Feed hold problem
    By kirby in forum Fanuc
    Last Post: 07-13-2007, 02:33 PM
