585,597 active members*
3,688 visitors online*
    Dec 2008
    41
    Boss 8 communications fail!
    Hi;
    I have a Bridgeport BOSS 8 CNC. It's give me good service for years. For a long time, I drip fed the machine from an old PC with EZUTIL from an old version of FEATURE CAM. Everything worked great. A bit clunky but dead reliable.
    Recently, my ancient computer died and could not be repaired. No problem I thought, I'll just run it from a modern laptop using a USB-Serial port adapter. I haven't been able to make it work with a new computer.
    The system operates much like it did before, everything seems fine. However, when I initiate a drip feed, nothing happens. I've tried two different USB-Serial adapters from different manufacturers and still the same problem, Have tried many combinations of serial port parameters (which I think should be Even, 7, 1 @ 4800 baud).
    Any help? Is anyone drip feeding a Boss 8 with a PC? If so, could you please share your setup with me?
    Thanks.
    Dec 2008
    41
    Re: Boss 8 communications fail!
    Bump, anyone?
  1. Specs and pics on Bridgeport Boss 5 thru Boss 12
    By Sakoman in forum Bridgeport / Hardinge Mills
    Last Post: 12-10-2016, 10:21 PM
  2. Replies: 1
    Last Post: 07-09-2011, 10:57 AM
  3. Communications Problem: PC--> Bridgeport Model R2E3 (BOSS 8)
    By rams_head in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2009, 03:15 AM
  4. Replies: 17
    Last Post: 06-11-2008, 01:19 PM
  5. Boss 5 Ezlink Communications
    By frog in forum Bridgeport / Hardinge Mills
    Last Post: 12-14-2007, 04:23 AM
