585,992 active members*
6,161 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > HSS86 and 2HSS86H Closed Loop Drivers
Results 1 to 10 of 10
    Mar 2018
    Does anyone have experience with HSS86 and/or 2HSS86H drivers?
    Changzhou Jinsanshi Mechatronics Co. Ltd.
    Step-servo driver 2HSS86H-2 phase step servo series-Product-Shenzhen Just Motion Control Electromechanics Co., Ltd.
    Is there a tuning software available for these drivers?
    How do they compare with Leadshine products in terms of quality?
    Thanks.
    Apr 2018
    6
    Re: HSS86 and 2HSS86H Closed Loop Drivers
    Did you get any info on these in the end, or buy and try to use? I'm also interested in the closed loop stepper designs.
    Mar 2018
    yes, I bought the JMC steppers with 2HSS86H directly from the factory. I have tested them only briefly. They seem to be good so far. Controller parameters are adjustable via an additional device (HISU) that came together with the motors. I will let you know as soon as I will test them in real load conditions.
    I have decided for the JMC because the JSS driver (HSS86) parameters are not adjustable.
    Mar 2018
    zorro321
    I am fondling the idea of purchasing the HSS86 model from Ratt Motor's stockhouse in Germany. No import duties this way and delivery within 15 days.
    But what you say is a bit alarming. No adjustment?
    It appears that there is a RS232 port on the HSS86 device. Doesn't this suit interface to a laptop (usb) and possibly allow for adjustment?
    Please fill me in with your on extra knowledge on the matter. I will appreciate it.
    Mar 2018
    My first option was JSS, too. I have contacted JSS directly regarding parameter adjustment. I have got the answer, that the RS232 port is only used to copy the driver software into the driver in the factory. The user cannot change parameters via this port.
    It is probably not a big deal, because most people will not adjust control loop parameters anyway, but I wanted to have more control in case of troubles. Micro-steps are selectable via on board switches.
    Mar 2018
    Clear enough!
    Actually my prospective supplier's listing states that the product offered is the 2HSS86H.
    I contacted them to verify on this and I inquired if a HISU adjuster is provided along with the package.
    time will tell
    thank you for now !!!
    Mar 2015
    70
    Hi guys,
    my NEMA34 8Nm with the HSS86 driver.
    the motor goes to position fault whenever home switch is triggered.
    what could ne happenening ? Mach3 through LPT to 5 axis BOB.
    Anyone ??
    Jan 2018
    Quote Originally Posted by shujaa View Post
    Hi guys,
    Anyone ??
    I've the same problem. When I give command to move the alarm driver blink 3 time each 3 sec. try to change on driver and cabling of a motor of the same model that go well. Nothing. I buyed to RATT Mator a nema 32 12Nm.
    They Say me Cabling problem (but the cabling is correct) and after that substitute the encoder but the problem is the same.
    Do you have resolve your problem. Could anyone help me
    thank in advance
    Mar 2015
    70
    My setup is dual motors on y axis. I have found it important to adjust both belts equally. Also to perfectly align the gantry.
    Quote Originally Posted by merlinogio View Post
    thank in advance
    Mar 2015
    70
    Also to decrease the acceleration of motor in motor tuning.
  1. Replies: 0
    Last Post: 07-13-2012, 10:32 AM
  2. closed loop steppers and drivers?
    By Knut in forum Stepper Motors / Drives
    Last Post: 07-10-2012, 11:11 PM
  3. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  4. Closed Loop Driver vs. Closed Loop Computer
    By ojibberish in forum Gecko Drives
    Last Post: 06-08-2004, 05:30 PM
