585,962 active members*
3,869 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Z Axis issue only when running grbl file
Results 1 to 3 of 3
    Mar 2018
    3
    Hi guys,
    I have been working on a CNC shield v3 build and have everything running with basic machine control (all axises work manually).
    When I run a "Circle-diamond-square" file all I get is a moan from the stepper on a -Z command.
    If I test the command manually it works. But not as the part of the program.
    I have tried a number of things, but I'm interested in your thoughts. Where should I be looking? Wha info do you need?
    Jason
    Apr 2004
    733
    Re: Z Axis issue only when running grbl file
    Quote Originally Posted by corran57 View Post
    Hi guys,
    Jason
    Probably moving the Z to fast in the gcode program. Try lowering the Z max speed and acceleration settings.
    $112 is Z max speed
    $122 is Z acceleration
    Mar 2018
    3
    Thanks, yes you might be right.
    Will have a play and let you know.
    J
  1. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  2. Where to get the Grbl .hex file?
    By rfresh737 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-30-2016, 04:30 PM
  3. Pen Plotter running GRBL
    By align600 in forum Videos
    Last Post: 12-20-2015, 08:26 PM
  4. Anyone have GRBL running on Arduino Nano?
    By hondaman900 in forum Open Source CNC Machine Designs
    Last Post: 04-20-2015, 08:10 PM
  5. Issue with Mach 3 Speed when running 4 Axis
    By redneck_cues in forum Mach Mill
    Last Post: 11-30-2014, 02:11 AM
