Hi guys,
I have been working on a CNC shield v3 build and have everything running with basic machine control (all axises work manually).
When I run a "Circle-diamond-square" file all I get is a moan from the stepper on a -Z command.
If I test the command manually it works. But not as the part of the program.
I have tried a number of things, but I'm interested in your thoughts. Where should I be looking? Wha info do you need?
Jason
