Dear sir, you can use Kflop to control two servomotors with external step dir signals
Hi dmoglianesi,
I don't fully understand your question. But yes KFLOP has Step/Dir Outputs. See:
Step and Direction Setup
Regards
TK
http://dynomotion.com
[QUOTE = TomKerekes; 2163902] Ciao dmoglianesi,
non capisco appieno la tua domanda. Ma sì KFLOP ha uscite Step / Dir. Vedi: Consigli
per l'impostazione passo e direzione
[/ QUOTE]
Dear Sir, I want to use an external signal, type gamepad or pulse generator, in real time and not in g-code and use kflop to control the motors in closed loop, thanks dalmazio
Hi dalmazio,
You can create a User Program for KFLOP to monitor an MPG (Manual Pulse Generator) and move one or motor axes (open or closed loop). You might download our software and look at the MPGSmooth.c example and see is if you can understand it.
Regards
TK
thanks, I certainly do not understand anything, but with your help I hope to succeed, first thing? what kind of signal and what inputs to use, thank you
Hi dmoglianesi,
Its hard to help someone when all they say is they don't understand anything.
What signals and inputs are you referring to?
Regards
TK
