584,865 active members*
4,867 visitors online*
Results 1 to 12 of 12
    Jun 2008
    14
    Haas VF2 way/spindle oil?
    I recently purchased a 98 Haas VF2 that has been very neglected. I removed the way covers and found large amounts of chips and rust. I found that the x axis was not getting way oil due to clogged metering valves. The linear slide has rust and was extremely dirty. I am trying to clean the metering valves due to them being $15 a piece but I have read that it may impossible to clean them. I would like to keep this from happening again so I am going to purchase the correct oil for the mechanical oiler. The oiler says to use Vactra #2 but the Haas website says to use Mobil SHC 625. From what I can see the mechanical oiler oils the ways and the spindle which seemed odd to oil the spindle with way oil. The oil tank has a large amount of sludge. The Haas website says to use Mobil SHC 625 due to Vactra causing sludge in the tank which I have. I know I'm gonna get blasted for asking but can I use some ISO 46 hydraulic oil which is the same viscosity and I have tons of it. The Haas website says the alternative is 5w-20 engine oil. I would think ISO 46 hydraulic oil would be a better choice. Keep in mind this is an old ragged out machine with bad liner slides and 17,000 hours. Check out the pictures of what I am dealing with. Thanks. I don't have a picture of the x axis but I will post later, it will make you cringe.
    Attachment 389342
    Attachment 389344
    Attachment 389346
    Attachment 389348
    Jun 2008
    14
    Re: Haas VF2 way/spindle oil?
    Here is what the Haas website says.
    Apr 2014
    344
    This is the first I’ve heard of this I thought vactra2 didn’t have wax in it and was good to go because it wouldn’t congeal?
    Jun 2008
    14
    Quote Originally Posted by ianagos View Post
    When I get back to the shop I will take a picture of the sludge. I don't want this to happen again and clog up the metering valves. They are kind of expensive, hard to replace, and not obvious when they clog up which could cause damage to much more expensive parts.
    Apr 2014
    344
    Quote Originally Posted by dwilley View Post
    My fadal recommends vactra 2 because it won’t gum up. Strange I need to check and replace the metering valves.
    Mar 2010
    1852
    What appears as sludge is probably old coolant oils.
    I just bought a 1999 VF-2. I'm a little further along in my cleaning and have come across several problems too. Let me know if you need any pics or anything else.
    Mar 2010
    1852
    Quote Originally Posted by fishyfishy View Post
    Year old post!
    15362
    I have some of the same year machines and have no sludge and use Vactra #2, the recommended oil by Haas, there is more going on than the oil, someone was probably mixing the oil with non machine quality oil
    Mactec54
    15362
    Quote Originally Posted by Machineit View Post
    Year old post!
    Yes it is surprising how often these post come up, but some are worth reviving because there quite often is new content that can be added
    Mactec54
    Mar 2010
    1852
    I agree, as I have two machines over 20 years old and no problems. I would stick with Vactra #2.
    DOH!!! I saw 3/20 and got excited that I might be able to help for once. :-) Thanks for pointing that out!
  1. -looking for - Haas spindle
    By tiitus in forum Haas Mills
    Last Post: 07-26-2017, 05:31 PM
  2. Haas TL2 spindle bearing!
    By garylb in forum Haas Lathes
    Last Post: 04-12-2012, 03:04 PM
  3. New Haas Spindle
    By JohnJW in forum Haas Mills
    Last Post: 03-08-2012, 05:08 AM
  4. Haas HL-4 Spindle
    By TFF-UK-LTD in forum Haas Lathes
    Last Post: 02-14-2011, 02:37 PM
  5. Just got a Haas VF1 with 30k spindle
    By rhettmandel in forum Haas Mills
    Last Post: 01-22-2006, 01:32 AM
