585,974 active members*
4,359 visitors online*
    Mar 2018
    UCCNC and UC300ETH-5LPT configuration issue
    I moved my CNC to another PC so I took configuration and copied to new pc. It works fine but the problem is that I have to manually load this configuration EVERY time I start UCCNC . I tried to load it, save it atc. But its allways starts with "Default config"...
    Does anyone know how to make it load my config by default upon start?
    Apr 2013
    1899
    Re: UCCNC and UC300ETH-5LPT configuration issue
    I don't remember the exact steps but know that it is clearly described in the manual. Anyway, every time you make a change you need to save it.
    Add the /p switch to the target in the shortcut to point to the profile you are using.
    Mar 2018
    /p profilename worked like a charm.Thank you
  1. Replies: 76
    Last Post: 03-27-2023, 11:26 PM
  2. UC100 vs UC300ETH-5LPT
    By Bad Wolf in forum UCCNC Control Software
    Last Post: 02-15-2020, 03:18 PM
  3. Replies: 1
    Last Post: 03-19-2018, 05:01 PM
  4. UC300ETH-5LPT Supplier
    By Tim_DGE in forum South Africa Club House
    Last Post: 02-23-2018, 05:05 PM
  5. Replies: 11
    Last Post: 02-13-2018, 03:08 PM
