586,013 active members*
4,137 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Rhino 6 "Update your Plug-ins" message
    Oct 2009
    96
    If you have loaded Rhino 6.2 and are wondering why you get a message to "Update your Plug-ins" and have not loaded any, just ignore the message.
    It looks at all prior version of Rhino to see what plugins you may have loaded and report which one are not V6 yet.
    So for example if you have Rhino5 with madCAM5 then Rhino 6.2 will bring up this message at launch.
    If you click on "Check now" it will tell you all the plugins you have even those that may have been installed and removed in the past (Registry Remnants still remain on those plugins).
    Regards,
    Mauri
    Mar 2004
    1661
    Re: Rhino 6 "Update your Plug-ins" message
    Great info, thanks!
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. 1980 wells index 805 cnc "rebuild" and update
    By Clayforrey in forum Knee Vertical Mills
    Last Post: 02-10-2018, 04:10 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. "Plug and Play" CNC controller.
    By [email protected] in forum Hobbycnc (Products)
    Last Post: 10-30-2007, 08:46 PM
