585,698 active members*
3,316 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Metalworking- / Woodworking Tooling / Manual Machining > Boring a Steep Parabola Into Bronze Round Stock with Lathe
    Feb 2018
    7
    Hello,
    I am looking to drill/bore a hole about an inch deep into brass round stock with a lathe. My problem is, I cant find the tool I need because I don't know what it's called. Are there drill bits with a parabolic tip? I found a "tree shaped burr," which is the basic shape I need, but I don't think it is for drilling. Basically, the hole needs to be parallel at the top, and parabolic at the bottom. The general shape I am looking for is in the attachment photo.
    Basically, the hole should look like an inverted pontiff's hat.
    Any help would be appreciated.
    Jesse
    Dec 2013
    5717
    Re: Boring a Steep Parabola Into Bronze Round Stock with Lathe
    It is possible to ''drill'' with a burr, sort of. A lot of really short pecks and clean the tool between pecks. Other than that, grinding a ''D'' drill might be the best option.
    https://www.tapatalk.com/groups/brit...t16025-s20.htm
    Scroll down about 1/3 of the page, shows a good picture
    Jim Dawson
    Sandy, Oregon, USA
  1. Flats On Round Stock.
    By fiduccian in forum Uncategorised MetalWorking Machines
    Last Post: 08-01-2014, 06:51 PM
  2. Fixturing Round Stock
    By totalhack in forum Tormach Personal CNC Mill
    Last Post: 06-27-2014, 05:35 PM
  3. Boring Bronze Bushings
    By stuby in forum MetalWork Discussion
    Last Post: 06-25-2010, 06:21 PM
  4. how does artcam do round stock, legs, etc?
    By lesd in forum ArtCam Pro
    Last Post: 10-25-2009, 03:48 AM
  5. 1018 Round Stock in SE PA
    By buckkillr8 in forum Employment Opportunity
    Last Post: 08-06-2007, 08:55 PM
