Originally Posted by
moldmker
(after issuing each m code, reset had to be pressed)
Is there a parameter setting to make these work correctly?
I have ladder and address diagrams but need help interpreting them.
Bob
Its a long time since I did anything on the 6m ladder, but if you can view the ladder you should be able to see the rung for that particular output and see what resets it.
When an M code is issued, the control has to see a Fin(ish) signal back, some M codes issue the Fin signal at once, like coolant on etc, where you don't need to wait for confirmation, But if your M codes are setting the relay on, that is the first step, but they hang, or wait for a Fin signal, that is why you have to push reset.
There may be one or more inputs that will trigger the Fin signal to allow the customisation you are looking for, you will have to study the inputs and outputs to be able to go any further, because obviously you would want to use another M code to reset the function.
Al.
Albert E.
