hy rcs
i am using a small code to get the shortest path for the C axis on lathes; i use this inside the program :
Code:
// some linear movement
CALL OCAXS LV01 = desired_C_value
// C axis movement
and i keep this soubroutine inside a *.ssb file :
Code:
OCAXS ( C_target )
IF [ ABS [ LV01 ] LT 360 ] NJUMP1
NLOOOP M0 ( cool man )
GOTO NLOOOP
NJUMP1 NOEX
IF [ LV01 GE 0 ] NJUMP2
NOEX LV01 = 360 + LV01
NJUMP2 NOEX LV01 = LV01 - VSIOC
IF [ [ [ [ [ LV01 GE 0 ] AND [ LV01 LE +180 ] ] EQ 1 ] OR [ LV01 LT -180 ] ] EQ 1 ] NTRUE
( NFALSE ) M16
GOTO NDONE
NTRUE M15
NDONE NOEX
RTS ( . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . )
( dif > +180 : M16 )
( 0 <= dif <= +180 : M15 )
( 0 > dif >= -180 : M16 )
( dif < -180 : M15 )
... it checks that -360 < target_value < +360
... converts negative value to positive ( eq -30 to +330 )
... it chooses a sense
to make it work on your cnc, you need the "equivalent system variable" for "VSIOC"
... i don't know, try VWKA* , VWKB*, * = A or B or C ?
kindly
