585,597 active members*
3,457 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Recommended Teknic Clearpath Motor for Prolight 2000 Retrofit
    Mar 2018
    Hi Everyone! I'm new to cnczone and was hoping I could get your help. I have 2 Prolight2000s. One of them is losing position on one of the axis without any error reported. I think it may be the encoder. I've been mulling over retrofitting one of these machines for years and I considered both a Mach 3 and an Acorn retro. Although the Acorn system is attractive, I don't like the fact I will need to buy a windows 10 machine to run it. I helped a customer setup a Tormach with an old P4 and a stripped down version of XP and it appears to run mach 3 just fine.
    Here's what I'm considering for hardware.
    Ethernet Smoothstepper
    C25 Terminal Board
    C41 PWM Spindle Control Board - to connect to the existing Minarik
    Teknic Clearpath SD motors and possible power supply if I can't use the existing one.
    My Questions -
    (1) What do you think of my proposed setup?
    (2) Which Clearpath Nema 23 model/s would you recommend?
    1st I talked to Magmotor the manufacturer of my original servos. The guy there said the specs would be between they're 230 and 300 model (see attachment) although these are 3/8 shaft and mine is 1/4 shaft
    When I sent this info to Teknic, I didn't get a recommended motor but got back a lot of resources about how to pick one which I am looking over but it's a little overwhelming. Considering this already has servo motors attached on the existing system I would think it would be easy to figure out a comparable Clearpath motor?
    When I get this figured out I'd like to post pictures of my progress to helpfully help other users.
    Any input would be greatly appreciated!
    Aug 2006
    670
    Re: Recommended Teknic Clearpath Motor for Prolight 2000 Retrofit
    do the current drives have a fault indicator?
    Seems unlikely that the servo itself would be the cause of position loss. I'd suggest looking over the mechanical aspects of the mill with a fine tooth comb before spending money on a new servo system. It may be something as simple as a loose motor shaft coupler.
    Mar 2018
    Quote Originally Posted by CS900 View Post
    Thanks for the response!
    I'm not getting any errors at the control. Yes, I did check the couplings and everything seems tight. I think I remember running an indicator in the spindle against a block and in jog mode it was fine. The position is always off by an exact amount. I forgot what that amount was maybe .040" inch. The reason I say encoder is I have a customer who makes robots and they said it was probably the encoder when I explained the problem.
    Sent from my LGMS550 using Tapatalk
  1. PROLIGHT 2000
    By ALHOULKER in forum Benchtop Machines
    Last Post: 07-05-2016, 04:16 AM
  2. Trying to get a proLIGHT 2000 up and running
    By voltsandbolts in forum Benchtop Machines
    Last Post: 01-24-2013, 08:47 PM
  3. Prolight-2000 Manuals
    By toddnv in forum Benchtop Machines
    Last Post: 07-31-2008, 06:16 PM
