585,949 active members*
4,131 visitors online*
    Apr 2008
    204
    Best way to have spindle error estop mach3
    Any suggestions from someone that has already applied this?
    Just had a brown out and mach 3 didn't get affected but the spindle did, almost broke my bit. I figure I would run a wire from the vfd to my breakout board, but does anyone have some nicer solutions.
    15362
    Re: Best way to have spindle error estop mach3
    Quote Originally Posted by davy182 View Post
    You don't say what VFD and Breakout Board you have, most VFD Drives you can use one of its built in Relays connected into the Estop circuit, are you running your machine with the same power source, there should only be ( 1 ) power source
    Mactec54
    Apr 2008
    204
    Thanks Mactec I'll check those I know it is a c32 board with ethernet smoothstepper with an smv vfd. I'll look up the model.
  1. Estop not working on Mach3 Interfaceboard
    By ppeettee in forum Mach Software (ArtSoft software)
    Last Post: 06-26-2019, 04:29 PM
  2. Replies: 1
    Last Post: 07-25-2015, 04:45 PM
  3. Mach3 ESTOP. Instant or decelerates??
    By neilw20 in forum Mach Software (ArtSoft software)
    Last Post: 08-21-2011, 12:38 AM
  4. hard overtravel estop error
    By chaz6966 in forum Cincinnati CNC
    Last Post: 11-14-2008, 03:43 PM
  5. Mach3 External Estop Requested
    By WarrenW in forum Mach Software (ArtSoft software)
    Last Post: 12-18-2005, 04:56 PM
