ACCURL IPG 1000W Fiber Laser Cutting Machine with CNC Laser Cutting Machine 1kw Price for Sale
ACCURL 1000Watt Fiber Laser Cutting Machine outshine with its fast cutting and energy efficiency abilities when especially its compared to CO2 Easy use, maintenance and service has been achieved by the high technology of Fiber Lasers. Globally recognized efficient components used in ACCURL Fiber Lasers add value to your company.
Features for Laser Cutting Machine:
1. User friendly FISCUT CypCut CNC control unit
2. Very easy to operate.
3. Quick and easy installation.
4. Low investment and operating costs.
5. The most cost-efficient solution for every requirement.
6. Flexible beam path
7. High output power
8. High optical quality
9. Up to %300 faster cutting
10. High wall plug efficiency (>%30)
11. Copper, brass cutting ability
12. Advanced Raytools cutting head (with air cross blast).
13. High performance and high accuracy rack and pinion system.
14. Dual proportional valve control system for different gas pressures and special system for high
Standard Equipment for Laser Cutting Machine:
1. FISCUT CypCut CNC Controller
2. IPG YLS-1000W Ytterbium Laser Resonator
3. Automatic Double Pallet Changer(Shuttle Table)
4. Precision Rack & Pinion Drive System (Made in Germany)
5. Radan or Lantek CAD/CAM system
6. Light source
7. Chiller
8. 3 lower protective lenses
9. Fiber Beam Transmission System (Fiber Cable)
10. Operates with both N2 and O2 (cutting) gases
11. Home Position Alignment System
12. Auxiliary Gas Selector
13. Auto Reflection Warning
14. Working Lights
15. 5 Nozzles each of the Following: (1.0mm, 1.2mm,1.5mm, 2.0mm , 2.5mm , 3.0mm)
Email:[email protected]
Phone Number:+ 86-18855551088
Website:www.cnc-press-brake.com
