585,991 active members*
6,409 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Rhino to Solidworks Errors
    Jan 2012
    55
    Good Morning,
    I am having some difficulty loading a Rhino file into Solidworks. I don't really know Rhino at all and have upper intermediate skills with Solidworks. So please be patient with me if I ask lots of what might seem obvious to the more experienced people.
    My issue is, I thought I would be able to directly import a Rhino .3dm file into Solidworks but when I try I get this message "The following file names entered were invalid, not found, locked or of an incompatible type". I tried saving them under different formats and so far have had no luck getting them to open.
    Is there anyone that successfully imports Rhino 3D solid files into Solidworks so that they can modified, and how are you accomplishing this?
    I've attached the file I'm trying to convert to Solidworks so I can edit some features within it. Any advise on the whole converting/editing process will be greatly appreciated as this is taking me way to long to figure out. I figure I'll have a whole bunch of things to learn about surfaces after I actually get the file to open.
    Apr 2004
    5737
    Re: Rhino to Solidworks Errors
    Try exporting it as an IGES (or .igs ) file. Rhino isn't a parametric program, so its file types aren't the same as Solidworks files, but you should be able to import the basic parts and parameterize them once they're open in SW.
    Andrew Werby
    Website
    Mar 2008
    683
    What version of rhino and what version of SW?
    Jan 2014
    16
    The filename has . decimal points in it, change the name by removing the . and it will load fine.
    Solidworks shows a number of faulty faces and many gaps in the model and recommends repairing and re_importing.
  1. Rhino Sketch to SolidWorks
    By skippy in forum Rhino 3D
    Last Post: 08-03-2015, 08:15 PM
  2. Rhino Sketch to SolidWorks
    By skippy in forum Solidworks
    Last Post: 08-03-2015, 08:10 PM
  3. Need help importing from Solidworks into Rhino
    By flathead in forum Rhino 3D
    Last Post: 06-04-2009, 10:32 PM
  4. Solidworks vs Rhino
    By sdantonio in forum Uncategorised CAM Discussion
    Last Post: 04-01-2006, 11:40 AM
  5. Rhino 3D 3.0 w/Flamingo or SolidWorks 2003 ?
    By samualt in forum Rhino 3D
    Last Post: 01-26-2004, 01:06 PM
