585,602 active members*
3,547 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Question for Clearpath servo users...
Results 1 to 8 of 8
    I'm currently using steppers and have panel mount DB-9 connectors that I have mounted on my control box that the stepper cables plug in to.
    For those of you using Clearpath servos, how are you connecting/passing the cabling into your control boxes? Are there panel mounts available for the different ports or are you just passing the cables through holes and hard wiring?
    Dec 2013
    5717
    Re: Question for Clearpath servo users...
    Why not just put a DB-9 connector on the end of the Clearpath cable? Or get a DB-9 breakout and wire the cable to the screw terminals
    Jim Dawson
    Sandy, Oregon, USA
    Yes, that would certainly work and was the kind of info I was looking for. And of course it wouldn't have to be a DB-9 breakout, could be any of a number of different connectors available.
    Mar 2004
    1804
    On mine, I used their their cables and then from DigiKey ordered the mating Molex connectors and pins.
    Art
    AKA Country Bubba (Older Than Dirt)
    Are the DB-9's capable of carrying the required current?
    Dec 2013
    5717
    Gerry, the Clearpath servos have a seperate power cable. The DB-9 connector should only be carrying a few mA of signal current.
    Jim Dawson
    Sandy, Oregon, USA
    Likely not. I'd use something more appropriate.
    Nov 2012
    1267
    Surprisingly, regular DB9 connectors are rated at 3 to 5 amperes per pin. I'm not saying it's a good idea to use them for power, but it's been done (including my own projects).
  1. Last One - 4'x6' Steel, Epoxy and ClearPath servo's
    By 1Jumper10 in forum CNC Wood Router Project Log
    Last Post: 02-15-2022, 08:09 AM
  2. Replies: 31
    Last Post: 10-01-2020, 01:13 PM
  3. Design phase question -- Clearpath SDSK + Acorn
    By pfmcnamara in forum DIY CNC Router Table Machines
    Last Post: 03-14-2018, 01:59 PM
  4. HELP!!! Wiring a Clearpath servo to a C32S - DUAL PORT MULTIFUNCTION BOARD
    By 09milam in forum SmoothStepper Motion Control
    Last Post: 01-26-2017, 03:11 AM
