585,994 active members*
4,692 visitors online*
    Sep 2016
    Excetek E500 wire EDM prolme
    hello
    i hope all is good, dear friends i have facing a problem in Excetek wire cut Model E 500, Year 2007. problem is machine interface says " over usable time, pleas enter password" i don,t have idea waht is password . if any one have idea about this machine. pleas tell us .thank you
    best reguards
    TEHMAS FIAZ
    Dec 2008
    10
    Re: Excetek E500 wire EDM prolme
    Dear Themas,
    I'm having the same problem with a Sure First Wedm, wich has the same system as your machine. Could you solve the problem? The answer would be a simple keygen, wich we don´t have. If you did, would you mind help?
    Regards.
    Hi tehmas,
    I want to ask something to you. We have a Jiten Edm wire cutter machine but it broken when we are running the machine 5 minutes later. on machine interface messagebox says : " over usable time, please input password?" . but we arent unlock this message . Did you solve your EDM machine ? maybe it is a similir problem.
  1. Simphoenix E500 VFD
    By Will_NZ in forum Spindles / VFD
    Last Post: 08-21-2017, 08:02 AM
  2. Replies: 0
    Last Post: 02-08-2017, 02:24 PM
  3. Integrex e500 Operator Opening In Houston, TX
    By Nick K in forum Employment Opportunity
    Last Post: 12-10-2010, 05:08 PM
  4. Integrex e500 Programmer Opening In Houston, TX
    Last Post: 12-10-2010, 05:06 PM
  5. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
