585,973 active members*
4,028 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Camworks Postprocessing pockets and face milling on a sinumerik 840D
Results 1 to 6 of 6
    Mar 2018
    Hi all,
    is it possible to use sinumerik cycles pocket3, pocket4, cycle71 in camworks postprocessor?
    I configured drilling cycles using sinumerik personalized cycles and there was no problem because in the UPG sections tab already exists drilling section categories.
    for pockets and face milling there are no sections, is it possible to create new sections or is there any other procedure to implement theese cycles?
    hope someone can answer
    Feb 2010
    69
    Re: Camworks Postprocessing pockets and face milling on a sinumerik 840D
    It's possible to implement them as post operation but you will not have simulation of them !! I don't see any advantage of using conversational programming within a CAM system...
    Mar 2018
    i was wandering... if the operator have to modify the program on the fly... maybe for a wrong allowance, if he could use the pocket cycle he could do it faster. no?
    Feb 2010
    69
    You could use the CNC compensation in NC tab to do this, I think it's less a risk than programming a pocket without any visual simulation, unless your machine cycle work exactly as the camworks pocket routines...
    Feb 2010
    69
    Mar 2018
    CNC compensation in NC tab can do it. It contains lesser risk than programming a pocket without any visual simulation, till the machine cycle work exactly as the camworks pocket routines.
  1. Sinumerik 840C, Sinumerik 840D
    By marek-vavra in forum SIEMENS -> Sinumerik 840C
    Last Post: 09-02-2022, 07:04 PM
  2. Replies: 2
    Last Post: 02-18-2020, 02:16 PM
  3. Camworks post processor for Siemens 840D
    By eldahan in forum CamWorks
    Last Post: 09-18-2016, 10:42 PM
  4. help whit sinumerik 840d
    By hayabusa6606 in forum EMCO CNC Machines
    Last Post: 12-16-2013, 01:15 AM
  5. Sinumerik 840D
    By M.RISHIKESH in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 05-24-2012, 03:14 PM
