585,741 active members*
4,989 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Need a very use-specific software
    Oct 2011
    19
    Question Need a very use-specific software
    Hello all!
    We have a Fanuc wire machine that we use to cut PCD disks into specific shapes for tooling. This process requires the piece be cut in such a way that a tit is not left on the bottom of the profile when the piece drops off. I already use nesting software to optimize that side of the process but right now the software we have to create a usable program is ANCIENT. It requires a specific computer running Windows 2000 Professional with a serial port license. I need to get rid of this ancient rock and get an updated program. The caveat comes in that it needs to allow me to manually trace out the path I need the wire to cut. We're talking super simple G01 XY and G02/G03 XYIJ movement. No 4 axis.
    wrap up:
    super simple CAM software
    MANUAL tracing of path to output
    Hoping someone will know of something out there! Thanks in advance for any help you can offer.
    Feb 2007
    412
    Re: Need a very use-specific software
    We have some very good easy to use Wire EDM software
    Dolphin CAD CAM USA - Affordable CAD-CAM Software
    ATB
    Andre
    Oct 2011
    19
    Quote Originally Posted by andre-dolphin View Post
    ATB
    Andre
    Will your software allow me to manually pick a path for the wire to follow?
    Feb 2007
    412
    Yes, you can choose exactly the path the software will take from your drawing.
    You can create the drawing using the 2D CAD module that is included or you can import DXF files.
    Oct 2011
    19
    Andre,
    Thank you for the information! I will be reaching out today to get more information.
  1. Software for restricting GCode to specific regions?
    By deonb1 in forum Uncategorised CAM Discussion
    Last Post: 03-11-2012, 11:26 PM
  2. X3 Specific tooling Q's
    By rezcar in forum Benchtop Machines
    Last Post: 03-19-2009, 02:52 AM
  3. Specific feed speed rates for specific wood
    By mcArch in forum WoodWorking Topics
    Last Post: 08-19-2008, 04:36 AM
  4. Are there specific router bits for specific materials?
    By fivefishcnc in forum Uncategorised MetalWorking Machines
    Last Post: 02-24-2008, 02:35 PM
  5. Which mill for specific job
    By fatboy55 in forum Benchtop Machines
    Last Post: 08-06-2006, 02:36 AM
